imagemaps with mapscript
Robert Chavez rchavez at perseus.tufts.edu
Fri Mar 10 09:38:44 EST 2000
Greetings,
I'm using mapscript to draw building polygons on a basemap; users can
select building names/types from an interface - mapscript pulls the
appropriate polygon data from a Postgres database, creates a shapefile
and adds and draws the polygon as a layer to the overall map.
What I'd like to do is create a client side image map out of these
building polygons.  Obviously, the polygon geo-coordinates are easy to
access, but is there some way to access the corresponding image
coordinates that get created when the polygon layer is rendered by
mapscript/mapserver?  There's probably an easy way to calculate what the
corresponding image coordinates would be, but I'm just not seeing it.
Any ideas?
Thanks,
Rob Chavez
