imagemaps with mapscript, part 2
Robert Chavez
rchavez at perseus.tufts.edu
Wed Mar 15 13:05:57 EST 2000
Thanks Steve.
I've put together a quick and dirty little Perl routine that does the
job
too, for what it's worth. Seems to work well so far.
I'm getting the coordinates for the shapes I want to render from a
Postgres
database -- these coordinates are retrieved in another routine and
stored
in @polygon in the form (point1x, point1y, point2x, point2y, point3x,
point3y ...),
Rob
sub create_imagemap {
#Read image width and height from map file
$imgwidth = $map->{width};
$imgheight = $map->{height};
#@polygon is a simple list that stores the real world coordinates of
the object pulled from the database
@vertices = @polygon;
#loop through the list grabbing each x and y coordinate and
converting
the geo-coordinate to image coordinates
while (@vertices) {
#grab first coordinate, remove any parentheses
$xvert = shift(@vertices);
$xvert =~ s/[\(\)]//g;
#convert x map coordinate to image coordinates
$cellsizex = (($map->{extent}->{maxx} -
$map->{extent}->{minx})/($imgwidth - 1));
$ximg = (($xvert - $map->{extent}->{minx})/$cellsizex);
#add image coord. to the new list
push (@imgshape,$ximg);
#grab second coordinate, remove any parentheses
$yvert = shift(@vertices);
$yvert =~ s/[\(\)]//g;
#convert y map coordinate to image coordinates
$cellsizey = (($map->{extent}->{maxy} -
$map->{extent}->{miny})/($imgheight - 1));
$yimg = (($map->{extent}->{maxy} - $yvert)/$cellsizey);
push (@imgshape,$yimg);
#form the <area> tag for html output
$coords = join(",", at imgshape);
$area = "\<area shape=\"polygon\" coords=\"$coords\"
href=\"URL-HERE\"\>\n";
print STDERR "$area";
push (@areas, $area);
Stephen Lime wrote:
> The easiest way would be to add a method to a shapeObj to apply a
> map to it. That is to clip, thin and transform the coordinates. It's a
> pretty easy addition. However, I've frozen development until I get the
> webCVS running with the folks at the UMN. It'll be a couple of weeks
> before I can make the changes.
> Steve
> Stephen Lime
