CGI Variable
Pericles S. Nacionales
pnaciona at gis.umn.edu
Mon Mar 20 20:54:37 EST 2000
Peter,
That CGI variable error message you encountered refer to the mapserver
mapfile. Since you are getting a CGI variable error, you at least have the
mapserv.exe in the right place. You don't have to do anything special with
it except to start writing an application. I suggest downloading the
MapServer demo for NT at http://128.101.73.80/ms_demo/ms_demo.zip and play
with it. To see how the demo should look, go to
http://128.101.73.80/ms_demo. You can also check the tutorial for MapServer
on NT at http://128.101.73.80.
These links should get you started.
-Perry Nacionales
----- Original Message -----
To: <MapServer-Users at lists>
Sent: Monday, March 20, 2000 3:27 PM
Subject: CGI Variable
> Hello,
> I'm using IIS 4.0 and I just downloaded the NT version of MAPSERVER. I
keep
> getting the following error:
> loadForm(): Web application error. CGI variable "map" is not set.
> How do I set CGI Variable under IIS?
> Please provide me with the step-by-step guidance since I never used this
> product before, thanks.
