CGI Variable
Peter Le ple at desolagroup.com
Tue Mar 21 12:34:23 EST 2000
Thanks for your feedback, but I still have problem with the below error.
The following is the command I used to test:
http://dgi/cgi-bin/mapserv.exe?http://dgi/cgi-bin/demo_map.txt
Is it possible that my IIS webserver does not have the CGI installation
setting?  If so, what can I do to enable it?
Thanks again for your help,
Peter
> -----Original Message-----
> From:	Pericles S. Nacionales [SMTP:pnaciona at gis.umn.edu]
> Sent:	Monday, March 20, 2000 8:55 PM
> To:	mapserver-users at lists.gis.umn.edu; Peter Le
> Subject:	Re: CGI Variable
> Peter,
> That CGI variable error message you encountered refer to the mapserver
> mapfile.  Since you are getting a CGI variable error, you at least have
> the
> mapserv.exe in the right place.  You don't have to do anything special
> with
> it except to start writing an application.  I suggest downloading the
> MapServer demo for NT at http://128.101.73.80/ms_demo/ms_demo.zip and play
> with it.  To see how the demo should look, go to
> http://128.101.73.80/ms_demo.  You can also check the tutorial for
> MapServer
> on NT at http://128.101.73.80.
> These links should get you started.
> -Perry Nacionales
> ----- Original Message -----
> From: "Peter Le" <ple at desolagroup.com>
> To: <MapServer-Users at lists>
> Sent: Monday, March 20, 2000 3:27 PM
> Subject: CGI Variable
> > Hello,
> > I'm using IIS 4.0 and I just downloaded the NT version of MAPSERVER. I
> keep
> > getting the following error:
> > loadForm(): Web application error. CGI variable "map" is not set.
> > How do I set CGI Variable under IIS?
> > Please provide me with the step-by-step guidance since I never used this
> > product before, thanks.
