Query expression and result
Peter Le
ple at desolagroup.com
Wed Mar 22 12:58:13 EST 2000
Thanks to some helps from the members in this list, I am able to load
graphic and data from mapserv. The only problem is when I click on the map,
the result comes back as : "getNumeric(): Incorrect data type" ...what
does this mean?
Also, in a query syntax, what does the "^-" indicate? i.e., EXPRESSION "^-"
Maybe a book about mapserver is needed :-)
Thanks,
