EMBED parameter
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Mar 22 17:48:06 EST 2000
Um, er. Forgot to update the docs for this one. Embeding works for scalebars
at this point. The EMBED parameter is not used rather you set the STATUS
to EMBED. You MUST have a markerset defined to use embedded scalebars.
They are actually added as a symbol and rendered using the noramal marker
utilities. Here's a typical definition:
SCALEBAR
STATUS EMBED
LABEL
SIZE tiny
COLOR 0 0 0
OUTLINECOLOR 255 255 255
END
STYLE 0
INTERVALS 3
SIZE 100 3
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 0 0 0
UNITS MILES
POSITION LR
TRANSPARENT TRUE
END # Scalebar
TRANSPARENT turns the image transparent. POSITION is similar to POSITION for labels.
Supported positions are UL,UC,UR,LL,LC,LR. Attached is an example image with an
embedded scalebar using the above definition.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> RAldridge <RAldridge at linuxstart.com> 03/22/00 03:19PM >>>
Does the EMBED parameter still work for legends and scalebars? I haven't tried it with a legend, but when I add 'EMBED true' to my scalebar parameters in my .map file, I get:
loadScalebar(): Unknown identifier. (EMBED):(67)
I don't know that I'd use it. Just wanted to see how it looks.
Thanks,
Robert Aldridge
Do you do Linux? :)
Get your FREE @linuxstart.com email address at: http://www.linuxstart.com
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000322/a5727b73/example.gif
