Mapserver compiled with Microsoft Visual C++
bfischer at usgs.gov bfischer at usgs.gov
Tue Mar 28 15:27:27 EST 2000
I want to thank Brent Fraser and Assefa Yewondwossena for helping me with
compiling mapserver for NT with freetype and libtiff.  I'm sorry I did not
try Brent's instructions, but they look like they would work just fine.  I
used Assefa's makefiles for Visual C++.  For anyone else that is new to
using Microsoft Visual C++, like myself.  I think it might be important to
add this to Assefa's step four:
These are insturctions to compile Freetype:
 - Open Visual C++
 - Open Workspace (File Menu) : ./freetype/lib/arc/win32/freetype.dsw. It
is a visual project file
(containing all the refernece to the source code).
 - Once it is loaded you go in the menu Build and you should see Build
freetype.lib. Select that and
it is supposed to build for you the library. I beleive the libaray will be
build in the directory
./freetype/lib/arch/win32/debug/freetype.lib.
- Once it is build, copy this library in the directory ./freetype/lib; this
is because the makefiles
from mapserver that I sent expect to find the freetype.lib in that
directory.
- Last step is to build mapserver using the command nmake /f makefile.vc in
the mapserver main
directory. There is also a readme.vc file for reference.
Thanks again,
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
