Mapscript on NT?
Norman Vine nhv at cape.com
Fri Mar 31 15:01:22 EST 2000
Stephen Luzny writes:
>If I try to compile Mapserver from scratch using CygWin B20 I get the
>following errors (I did not modify the Makefile in any way):
>gdttf.c:14: freetype.h: No such file or directory
You need to install the freetype library
http://www.freetype.org/
>map.h:35: regex.h: No such file or directory
You need to install the regex library
get it from any gnu archive
http://www.gnu.org
Norman
