Tiled data
Stephen Lime
steve.lime at dnr.state.mn.us
Wed May 3 10:30:55 EDT 2000
Your layer definition might look like:
LAYER
NAME sections
DATA sections # or whatever the name common to each directory is
TYPE POLYLINE
TILEITEM location # or whatever the item storing the tile path information is
TILEINDEX /gisdata/index
.... class/query/scaling stuff ...
END
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> RAldridge <RAldridge at linuxstart.com> 05/02/00 12:17PM >>>
We have an ArcInfo Library that I want to replicate to tiled shapefiles for use with MapServer. I've set-up the directory structure on my mapserver box as follows: /gisdata/a1, /gisdata/a2, /gisdata/a3.../gisdata/j11. So, I have a rectangular grid that I use for my index that has 110 tiles. If my index.shp file is located in /gisdata, what should my .map file entry look like to draw section lines (sections.shp), for instance.
I had this working before, but can't seem to figure it out now.
Thanks,
Robert Aldridge
Do you do Linux? :)
Get your FREE @linuxstart.com email address at: http://www.linuxstart.com
