Trying to implement an identify tool
Stephen Lime
steve.lime at dnr.state.mn.us
Fri May 5 18:05:16 EDT 2000
This is pretty easy using the standard MapServer or MapScript for that matter. You just need a little javascript to change the form target when the mode changes. That's how the data deli works. When a user wants to do a query, just before submission a results window is opened and the target property of the form is changed to use that window. That target could be a frame, a window or even a css layer. To do this implement an onSubmit
method for your main form and do a little checking just before submitting the form.
BTW LandView and it's underlying code will support this as well.
Steve
Steve
<<< <bfischer at usgs.gov> 5/ 5 2:38p >>>
I am trying to implement an identify tool similiar to how ArcView IMS
works. I was wondering if anyone else has implement something like this
with mapserver. What I want is a seperate window to appear after a feature
is clicked on. This would be fairly simple if we could use a javascript
function like window.open in the template parameter of a layer query. Is
there any way to do something like this with the current version of
mapserver?
Thanks,
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
