problem with fonts and demos
Marcio Augusto Stocco stocco at prodam.sp.gov.br
Thu May 25 18:09:59 EDT 2000
I hadn't had these problem, because I've built up the files with ls and
awk. But the following message from Stephen Lime has put me in the right
way, and now I got the demo running.
Thank you very much indeed,
Márcio.
Date: Thu, 25 May 2000 12:24:40 -0500
To: stocco at prodam.sp.gov.br
Subject: Re: problem with fonts and demos
There was a slight change in line symbol file formats from 3.2 to 3.3.
Copy the symbol
files from the 3.3 distribution (in the symbols directory) to the demo
symbols directory
and that should fix it. You may still hit a few other snags but those are
mostly outdated
parameters and you can just delete or comment out those lines.
Steve
Stephen Lime
Internet Applications Analyst
On Thu, 25 May 2000, mocha wrote:
> i think your files may contain ^M at the end of each line. i had the same
> problem. more file.name didn't show it. but it did show in vi. you'd need
> to s/r all of the ^M (remove them).
> At 11:08 AM 5/25/00 -0300, Marcio Augusto Stocco wrote:
> >Hi,
> >I installed MapServer 3.2 and the 3.2 Demo, and it works ok, but doesn't
> >draw the city names.
> >I've downloaded some free true type fonts from the web, and put them in
> >/usr/apps/mapserv/symbols/fonts. Then, I modified the font directory name
> >in the mapserv.ini file. After that, I wrote two diferent fonts.list file,
> >because the README statement doesn't match the example file.
> >Unfortunatelly, neither worked.
> >After the message about the 3.3 demo, I decided to upgrade. But now, I
> >can't even get the first map. When initializing, mapserv displays the
> >following error message:
> >msLoadSymbolFile(): Unknown identifier. ():(0)
> >Any clue will help.
> >Thanks in advance,
> >Márcio.
