mapscript Perl module
Daniel Morissette
danmo at videotron.ca
Tue May 30 13:24:18 EDT 2000
Zolla Michalak wrote:
> The same program DOES work with mapscript when compiled and run from UNIX,
> just not from the web. It think this might be a library path problem.
> Before compiling in UNIX, I have to give it this command: setenv
> LD_LIBRARY_PATH /local/tiff-3.4/lib:$LD_LIBRARY_PATH. I tried setting the
> path in my .login file, but that didn't seem to help. I might have the
> syntax wrong though. Here is the setenv line from my .login file: setenv
> LD_LIBRARY_PATH /usr/lib:/usr/local/lib:/local/tiff-3.4/lib
> Any suggestions?
If you're using Apache then the value of LD_LIBRARY_PATH is not
automatically passed to the CGI scripts. You can add a PassEnv or
SetEnv directive to your httpd.conf with the value that should be passed
to your CGI scripts. See:
http://www.apache.org/docs-1.2/mod/mod_env.html#setenv
Daniel Morissette danmo at videotron.ca
http://pages.infinit.net/danmo/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
