Projection support for SDE, images, ...
Haavard Tveite
havard.tveite at ikf.nlh.no
Fri Nov 3 10:46:35 EST 2000
Stephen Lime wrote:
> There's been no work on either to date. With SDE the API documentation is
> *very* poor. Since I haven't needed it I haven't pursued it. I'd prefer to
> take advantage of ESRIs projection engine but it may be that PROJ.4 support
> is easier to support.
I found "msDrawShape(...)" in maputil.c. It seems to use proj.4, and could
perhaps be used directly from mapsde.c to draw the retrieved shapes.
On the other hand, "msDrawShape(...)" currently does not seem to be called
from anywhere.
Has it been tested/used?
Could it do most of the job that msDrawSDELayer(...) (in mapsde.c) currently
does?
> Steve
> >>> Haavard Tveite <havard.tveite at ikf.nlh.no> 11/03/00 07:35 AM >>>
> Two questions:
> 1) How far has the work on supporting projections for SDE
> come?
> The last "nightly" I checked (oct. 25th) had no trace
> of projection support in the mapsde.c file.
> It would be *very* useful to have this available also
> for SDE (not only for shapefiles), particularly for us
> living considerably closer to the north pole than to
> the equator!
> Håvard Tveite Phone: +47 64948857
> Department of Mapping Sciences Fax: +47 64948856
> Agricultural University of Norway
> POBox 5034, N-1432 Ås, NORWAY http://www.nlh.no/ikf/ikf.html
