What's wrong with this mapfile?
Pericles S. Nacionales pnaciona at gis.umn.edu
Mon Nov 6 11:45:52 EST 2000
Steve and list,
I actually updated the download page this weekend and added a page
specifically for NT binaries.  I have two versions of 3.3.011 release as
well as two of 3.3.012 nightly release (from 11/03).  By versions I meant
support for GIF or PNG.  If you are downloading the version with PNG support
and would like to use it with MS_DEMO, please be aware that there are
symbols that refer to GIF graphics.  You will need to convert those into PNG
and update the symbol file (I think it's in marker.sym).
Anyway, the new page can be accessed from
http://mapserver.gis.umn.edu/dload.html or directly at
http://mapserver.gis.umn.edu/win32binaries.html.
Ciao!
Perry N.
----- Original Message -----
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
To: <rgu at ems.muenchen.de>; <mapserver-users at lists>;
<Markus.Spring at muenchen.de>
Cc: <david at kriske.com>
Sent: Monday, November 06, 2000 9:47 AM
Subject: Re: What's wrong with this mapfile?
> Me thinks there is a memory error in 3.3.011 somewhere. It's rare but for
> some reason it appears somewhat arbitrarily. Certain settings seems to
cause
> a problem, they're symptoms but not the cause. Would you be willing to
> try your application against the nightly build?
> Since you don't use any non-default symbols it should be an easy port.
Just
> strip out the symbol set lines and use the new version.
> Much of the work on 3.3.012 has focused on tightening up the code and it's
> probably the most stable version ever. (Perry could you post a 3.3.012 NT
> binary as well? Call it nightly.zip.)
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> rgu at ems.muenchen.de 11/06/00 02:53AM >>>
> Hello list,
> I have a problem with the mapfile below:
> It doesnt render until I either
> * comment out the MAXSCALE in layer MSblock92
> or
> * comment out STATUS ON in the legend (resulting in no legend being
> created)
> or
> * activate the fourth class "Nicht bewertet"
> If one of these three conditions is met, the mapfile works like a charm.
> I do have no explanation for this unlogical behavior and would be very
> glad, if someone could point me out what's wrong with this map
> definition.
> Kind regards - Markus W. Spring
> # MAPTITLE "Öffentliche Grünflächen und Wald"
> # Start of map file
> STATUS     ON
> SIZE       500 350
> #SYMBOLSET  "/data/web/ms_demo/symbols/symbol.sym"
> SHADESET   "/data/web/ms_demo/symbols/shade.sym"
> MARKERSET  "/data/web/ms_demo/symbols/marker.sym"
> LINESET    "/data/web/ms_demo/symbols/line.sym"
> FONTSET    "/data/web/ms_demo/symbols/fonts/fonts.list"
> UNITS      METERS
> IMAGECOLOR 255 255 255
> EXTENT 51199 23918 80829 46732
> NAME k1_5_1
> # Start of web interface definition
> WEB
>   TEMPLATE  /data/web/ms_demo/k1_5_1/k1_5_1.html
>   MINSCALE  2000.0
>   MAXSCALE  1550000.0
>   IMAGEPATH "/data/web/tmp/"
>   IMAGEURL  "/tmp/"
> END # WEB
> # Start of legend
> LEGEND
>   STATUS ON
>   LABEL
>     TYPE TRUETYPE
>     FONT arial
>     SIZE 10
>   END
> END # legend
> LAYER
>   NAME l24
>   DESCRIPTION "Gruenflaechen und Wald"
>   DATA /data/ua_shr/flaenutz/shapes/grwald
>   TYPE POLYGON
>   CLASSITEM "CODE"
>   CLASS
>     NAME       "Wald"
>     EXPRESSION ([CODE] eq 1.00000000000000)
>     COLOR 1 100 0
>     OUTLINECOLOR 0 0 0
>   END # class
>   CLASS
>     NAME       "Parks" # und Grünanlagen, Friedhöfe"
>     EXPRESSION ([CODE] eq 2.00000000000000)
>     COLOR 1 160 0
>     OUTLINECOLOR 0 0 0
>   END # class
>   CLASS
>     NAME       "Kleingartenanlagen"
>     EXPRESSION ([CODE] eq 3.00000000000000)
>     COLOR 247 181 103
>     OUTLINECOLOR 0 0 0
>   END # class
> #   CLASS
> #     NAME       "Nicht bewertet"
> #     EXPRESSION ([CODE] < 0)
> #     COLOR 255 255 255
> #     OUTLINECOLOR 0 0 0
> #   END # class
> END # layer l24
> # Background layer blockkarte
> LAYER
>   NAME MSblock92
>   DESCRIPTION "Blockkarte"
>   # STATUS DEFAULT
>   TYPE Polygon
>   DATA /data/ua_shr/muc/shape/block92
>   MAXSCALE 50000.0
>   CLASSITEM "BLOCK92_"
>   CLASS
>     NAME "Baubloecke"
>     SYMBOL 0
>     COLOR -1 -1 -1
>     OUTLINECOLOR 165 165 165
>   END # class
> END # layer MSblock92
> END # map
