nquery templates
Robin.Ellis at dnr.qld.gov.au
Tue Nov 7 18:04:55 EST 2000
Does anybody know how to 'trick' mapserver into accepting a URL query
template for an NQUERY? I'd like to be able to do this so that I could also
employ header and footer files, which require a multi-result query.
I'm using a Java based application on a UNIX platform that uses standard map
files.
Thanks
Rob
Robin Ellis
Land Resources Officer
Department of Natural Resources
Burnett District
ph: 07 4131 5771
fax: 07 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
