Rotating text labels for a street map
Berend Veldkamp
berend.veldkamp at aris.nl
Wed Nov 8 11:43:10 EST 2000
I haven't found the 'ANGLE auto' in the documentation either, but it does work.
If you have compiled with TT support.
Berend
Brian Johnson wrote:
> As always, I research my problems by searching the archives, but I can't
> find the answer to this.
> I'm trying to get text labels to rotate to match the lines they are
> associated with - I've found examples of using ANGLE AUTO in the LABEL
> section of the mapfile but there isn't any refernence to it in the map file
> documentation.
> I'm wondering if my problem is that I didn't compile in support for TruType
> fonts.
> Do I need to complile in TrueType fonts to use auto angle or has that
> feature been dropped?
> I tried to check other pages (including the freetype web page) but couldn't
> find any reference to rotating text.
_________________________________________________
ARIS - Hooghiemstraplein 126 - NL 3514 AZ Utrecht
tel. +31 30 2769180 - fax. +31 30 2733578
URL: http://www.aris.nl/
