FOLLOW UP: Can't declare multiple MAXSCALE's
David L. Kriske david at kriske.com
Wed Nov 8 18:57:39 EST 2000
I am still having trouble inserting multiple MAXSCALE statements in my map
file.  I have since tried compiling mapserver on a Linux machine and get
the same behavior when adding multiple MAXSCALES.  I have also tried
changing the units to meters as suggested.  Could it be a shapefile
specific error?  What other areas does the MAXSCALE function depend upon?
David
--- previous message forwarded below ---
I'm running Mapserver 3.3.011 (also tried .012) compiled for NT 4.0 (using
the precompiled
one on the mapserver site).  For some reason, I am unable to declare a
MAXSCALE statement for more than one layer.  If I do, I get...
Mapserv.exe Application Error - The instruction at <big memory address>
referenced memory at "<another big memory address>". The memory could not
be "written"
Then Mapserver bombs and I get a CGI Error in the browser.
If I take out all but one (or all) of the MAXSCALE statements it renders
the map
fine.  I'm using the Maperserver Tutorial Example 4 adjusted to use my own
shapefiles.  I haven't tried running Mapserver on a Linux Box, is the NT
build buggy?  Here's my .map file if it helps.....
Thanks in advance for any help you may provide.  This seems to be a great
program in every other respect!
David
NAME AOP
EXTENT -126 45 -65 30
FONTSET "d:\inetpub\wwwroot\mapserver\fonts\fontset.txt"
UNITS dd
SIZE 500 500
SHAPEPATH "e:\MAPSERVER\SHAPES\"
  WEB
    TEMPLATE "d:\inetpub\wwwroot\mapserver\browser.html"
    IMAGEPATH "d:\inetpub\wwwroot\mapserver\images\"
    IMAGEURL  "/mapserver/images/"
  END
  LEGEND
    STATUS ON
    LABEL
      TYPE TRUETYPE
      FONT arial
      COLOR 0 0 0
      SIZE 12
      ANTIALIAS
    END
  END
  SCALEBAR
    STATUS ON
    INTERVALS 2
    SIZE 100 2
    COLOR 0 0 0
    OUTLINECOLOR 0 0 0
    UNITS miles
    LABEL
      COLOR 0 0 0
      SIZE medium
    END
  END
  LAYER
    NAME "us"
    DATA us
    STATUS DEFAULT
    TYPE POLYGON
    CLASS
      COLOR 212 212 212
      OUTLINECOLOR 140 140 140
    END
  END
  LAYER
    NAME "aops"
    DATA aop102500_8
    STATUS DEFAULT
    TYPE POLYGON
    CLASS
      NAME "AOP"
      COLOR 102 110 176
    END
  END
  LAYER
    NAME "freeways"
    DATA roads
    CLASSITEM "CFCC"
    STATUS DEFAULT
    TYPE LINE
    CLASS
      NAME "Freeways"
      EXPRESSION /A1[0-9]/
      COLOR 223 0 41
    END
    MAXSCALE 50000
  END
  LAYER
    NAME "roads"
    DATA roads
    CLASSITEM "CFCC"
    STATUS DEFAULT
    TYPE LINE
    CLASS
	  NAME "Major Arterials"
	  EXPRESSION /A[2-3][0-9]/
	  COLOR 245 183 87
	END
	MAXSCALE 100000
  END
  LAYER
    NAME "streets"
    DATA roads
    CLASSITEM "CFCC"
    STATUS DEFAULT
    TYPE LINE
	CLASS
	  NAME "Minor Streets"
	  EXPRESSION /A[4-7][0-9]/
	  COLOR 0 0 0
	END
  END
END
