Questions on layer display, Rosa applet
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Nov 9 15:21:15 EST 2000
Ignore STATUS settings other than DEFAULT. The mapserv CGI program
considers anything but DEFAULT to be OFF. Then the app looks for CGI
variables called "layer" the mapserver layer referenced by that layer, for
example lakes, is then considered ON. Study the demo.
See the attached applet and class files.
To use:
1) place the class files on your site someplace (preferable in their own directory)
2) add the following javascript functions to your application (in the <head> section)
<script language="javascript">
function mapplet_apply(name, minx, miny, maxx, maxy, redraw) {
document.mapserv.imgbox.value = minx + " " + miny + " " + maxx + " " + maxy;
document.mapserv.imgxy.value = minx + " " + miny;
function mapplet_error(message) {
alert(message);
</script>
3) add the following hidden variables to your mapserver form (make sure the form is named "mapserv", if you change
it you'll need to edit the functions above to reflect that change)
<input type="hidden" name="imgxy" value="149 199">
<input type="hidden" name="imgbox" value="-1 -1 -1 -1">
The values for imgxy should be matched to you're image size. The formulas are x = (cols-1)/2 and y = (rows-1)/2.
4) change the <input type="image"...> part of your form to use the applet.
<applet codebase="/mapping/java/mapplet" code="mapplet.class" width="300" height="400" name="mapplet" MAYSCRIPT>
<param name="image" value="http://www.dnr.state.mn.us/[img]">
<param name="jitter" value="10">
<param name="thickness" value="2">
<param name="color" value="yellow">
</applet>
where
image = fully qualified URL for the image to be displayed
jitter = the ammount of slop in mouse clicking (i.e. minimum box size)
thickness = thickness of the dragged box (in pixels)
color = color of the box (either a java named color or an rgb triplet - 0 0 0)
You'll have to edit the codebase, width, and height parameters to match your needs.
That should do it.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Ben Lewis" <benlewis1 at hotmail.com> 11/07/00 01:55PM >>>
Stephen,
Thanks for the quick response...
In the map file in the demo, all layers have status=on or status=default.
How does the interface in the demo turn them on and off from the "select
layers to display" box on the browser interface? When I highlight a layer to
turn on and hit refresh, no change occurs and the layer i highlighted is no
linger highlighted. In the original demo any layers that are highlighted
are turned on when the map is refreshed.
I hope this makes sense.
Yes, I would be very interested in the applet you mentioned.
Thanks again.
Ben Lewis
Advanced Technology Solutions, Inc.
Lancaster, PA
>From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
>To: <benlewis1 at hotmail.com>
>Subject: Re: Questions on layer display, Rosa applet
>Date: Tue, 07 Nov 2000 12:59:38 -0600
>By default all layers are off and must be explicitly turned on. The
>exception is
>layers of TYPE DEFAULT or QUERYONLY. The layer and layers CGI variables
>are used to specify which layers to turn on.
>BTW I have an alternative to Rosa that can be added to an application in a
>few minutes if you're interested.
>Steve
>Stephen Lime
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
> >>> "Ben Lewis" <benlewis1 at hotmail.com> 11/07/00 10:50AM >>>
>I started with the demo and loaded my own data, everything is going well
>reprojection, query - except I can't get the layers to turn on and off.
>Status=default gets them on. Status=on does not, but I cannot turn them on
>from the "Select Layers to Display" window. Any help appreciated.
>BTW MapServer is fast. I've got a 100 meg shape file I'm cruising around
>w/
>4 second refresh times on a 260 megahertze! That's indexed using shptree.
>One other question, the Rosa applet looks very nice, and I'm going to be
>giving a presentation on Open Source GIS, using MapServer (and the Rosa
>applet if possible) as an example of a great OS GIS web apps, and wanted to
>see if there was a quick how to that could get the applet running in an
>hour
>or so. No big deal if it's more involved than that.
>Thank you.
>Ben Lewis
>Lancaster, PA
>_________________________________________________________________________
>Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
>Share information about yourself, create your own public profile at
>http://profiles.msn.com.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001109/b233a327/mapplet.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001109/b233a327/mapplet.class
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001109/b233a327/evalThread.class
