request for the answer
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at peligroso.gaiaenv.com
Mon Nov 13 19:37:54 EST 2000
Hi rupesh,
This is more of an ArcView question than a MapServer question.
Having said that, the answer is 'yes' you can georeference an image
using ArcView using the appropriate extension. Check the ESRI site for
extensions/scripts to download. I think some of these let you enter the
'real-world' GCP coordinates manually and then interactively select the
image coordinates.
http://gis.esri.com/arcscripts/scripts.cfm
mamidi at ncche.olemiss.edu wrote:
> I am a gradute student in university of mississippi and want the
> answer for the following problem. I want to georeferencce an image . If I
> dont have the shape file file for that image and If I can get the GCP's for
> that image then which is the best way to georeference the image. Is it
> possible to do that in arcview. Is there any simple and good extension
> which I can download from internet. thanks in advance
> rupesh K mamidi
