PHP DrawReferenceMap
Berend Veldkamp b.veldkamp at zonnet.nl
Thu Nov 16 11:34:25 EST 2000
Everything seems OK, the image is there, I also tried using the full
pathname. But still no go.
Only the image needs to exist, not some kind of reference file, like
ArcInfo uses, right?
Berend
Daniel Morissette wrote:
> Berend Veldkamp wrote:
> > Do I need something special to get DrawReferenceMap going in PHP?
When I
> > do
> > $map->drawReferenceMap();
> > All I get is:
> > Fatal error:  MapServer Error in msDrawReferenceMap(): Unable to
> > initialize image. in refmap.php on line 4
> > (Line 4 = $map->drawReferenceMap();)
> You get this error when drawReferenceMap() fails to load the base
> REFERENCE map IMAGE.
> Make sure that the file specified for REFERENCE -> IMAGE in your .map
> file exists, and that it is in a format that your version of GD
> understands, i.e. GIF for GD < 1.6, PNG for later versions.  (Could
also
> be JPEG if you have GD 1.8 compiled with JPEG)
>  Daniel Morissette                morissette at dmsolutions.ca
>                 http://www.dmsolutions.ca/
