Setting Paths
Pericles S. Nacionales pnaciona at gis.umn.edu
Wed Nov 22 15:10:40 EST 2000
On your map file, do your IMAGEPATH and IMAGEURL look like this?
<stuff deleted>
WEB
    IMAGEPATH "g:\tmp\"
    IMAGEURL "/tmp/"
END
<more stuff deleted>
And do you have g:\tmp virtual directory set as /tmp on your web server?
-Perry
----- Original Message -----
From: "Kieran J. Ames" <kames at keyspanenergy.com>
To: <mapserver-users at lists>
Sent: Wednesday, November 22, 2000 12:00 PM
Subject: Setting Paths
> Group,
> In getting the demo running, I'm running across some path issues that I
> don't understand.
> Running NT4.0 Mapserver 3.3.012
> The Mapserv executable is in g:\_PublicWebSite\cgi-bin\mapserv
> The demo is in g:\_PublicWebSite\wwwroot\ms_demo
> The tmp directory (for images) is in g:\tmp. All directories have
> appropriate read & write access and virtual directories are defined as
> well.
> The problem: the DEMO images are being written to
> g:\_PublicWebSite\wwwroot\ms_demo and not to the tmp directory I thought
> they'd be written to. I modified read and write access to get the page
> to work. If I then change the pointer tags in demo.html from
> SRC="[img]"     to   SRC="../../ms_demo/[img]"
> then it all seems to work properly. However, that doesn't seem to be the
> best way of doing things.
> I understand that there is no longer a mapserv.ini file. How can I get
> the files to write where I want them to?
> Thanks for the help (and Happy Thanksgiving to all).
> Kieran
