scale, scalebar & units
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Nov 22 17:29:08 EST 2000
Could be an error in the conversion factors in mapscale.c. I don't use kilometers
much. What data are you using that stores is coordinates in kilometers? That's not
real common.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Hendrik Meij <hmeij at mail.wesleyan.edu> 11/22/00 02:15PM >>>
Allright, befuddled.
I have a spain demo i'm tinkering with...the entire country is 0.8 miles
across according to the scale. My map units are set to kilometers,
scalebar is defined (also kilometers with intervals of 4) but not scale (as
the doc tell me the app will set this). In arcview the shapefile yields
correct distance measurements. Where do i look for an answer?
-Henk
Hendrik K Meij ph: 860.685.3477 fax: 860.685.2401
Applications Technology Specialist http://www.wesleyan.edu/
