Rosa applet question
Assefa Yewondwossen assefa at dmsolutions.ca
Wed Nov 29 13:22:54 EST 2000
Hi There,
 I think the problem is with the setting of the IMG_URL parameter :
 <PARAM NAME="IMG_URL" VALUE="". /mapimages/ . 18895975509219.gif ."">
 It should be something like
<PARAM NAME="IMG_URL" VALUE=" /mapimages/18895975509219.gif ">
 I will update the rosa applet so that an appropriate error message will be
displayed if the image is not found.
 As for the location of the rosa.jar, it should (based on your html) be placed
in the same directory as your html file.
Please let me know how it goes,
Later,
Robert Chavez wrote:
> I've been playing around with the DMSolutions Rosa applet and am having some
> trouble getting it set up properly.  I've been getting some java errors that
> I haven't seen before and I was wondering if anyone had some suggestions as
> to what the problem is.
> I'm running this on Red Hat Linux 6.2 using jdk1.2.2, but I've also tried
> jdk1.1.7v3 and got the same results.  Paths and classpaths are fine, and
> netscape's java40.jar is in the correct place and in the class path. The
> HTML is generated from a CGI script, so I've moved the jar and class files
> into the cgi-bin under the assumption that this is where they need to be.
> I'm no applet guru, so I've probably just overlooked something obvious.  Any
> ideas?
> Thanks,
> Rob Chavez
> Programmer/GIS Specialist
> Perseus Project
> Here's my applet HTML code, I haven't appended the whole HTML file here as
> it's quite long:
> <APPLET NAME="RosaApplet" ARCHIVE="rosa.jar" CODE="Rosa2000.class"
> WIDTH="600" HEIGHT="400" MAYSCRIPT>
> <PARAM NAME="TB_POSITION" VALUE="right">
> <PARAM NAME="TB_ALIGN" VALUE="top">
> <PARAM NAME="INP_FORM_NAME" VALUE="atlas">
> <PARAM NAME="TB_BUTTONS" VALUE="zoomin|zoomout|recenter|pquery">
> <PARAM NAME="INP_TYPE_NAME" VALUE="imgext">
> <PARAM NAME="INP_COORD_NAME" VALUE="imgext">
> <PARAM NAME="TB_SELECTED_BUTTON" VALUE="zoomin">
> <PARAM NAME="TB_BUT_zoomin_IMG" VALUE="/icons/icon_zoomin.gif">
> <PARAM NAME="TB_BUT_zoomin_IMG_PR" VALUE="/icons/tool_zoomin_2.gif">
> <PARAM NAME="TB_BUT_zoomin_HINT" VALUE="Zoom in: Click the button|and the
> map will zoom in">
> <PARAM NAME="TB_BUT_zoomin_INPUT" VALUE="auto_rect">
> <PARAM NAME="TB_BUT_zoomin_NAME" VALUE="zoomdir">
> <PARAM NAME="TB_BUT_zoomin_VALUE" VALUE="1">
> <PARAM NAME="TB_BUT_zoomout_IMG" VALUE="/icons/icon_zoomout.gif">
> <PARAM NAME="TB_BUT_zoomout_IMG_PR" VALUE="/icons/tool_zoomout_2.gif">
> <PARAM NAME="TB_BUT_zoomout_HINT" VALUE="Zoom out: Click the button|and the
> map will zoom out">
> <PARAM NAME="TB_BUT_zoomout_INPUT" VALUE="submit">
> <PARAM NAME="TB_BUT_zoomout_NAME" VALUE="zoomdir">
> <PARAM NAME="TB_BUT_zoomout_VALUE" VALUE="-1">
> <PARAM NAME="TB_BUT_recentre_IMG" VALUE="/icons/icon_recentre.gif">
> <PARAM NAME="TB_BUT_recentre_IMG_PR" VALUE="/icons/tool_recentre_2.gif">
> <PARAM NAME="TB_BUT_recentre_HINT" VALUE="Recenter: Click the button|and the
> map will recenter">
> <PARAM NAME="TB_BUT_recentre_INPUT" VALUE="auto_point">
> <PARAM NAME="TB_BUT_recentre_NAME" VALUE="zoomdir">
> <PARAM NAME="TB_BUT_recentre_VALUE" VALUE="2">
> <PARAM NAME="TB_BUT_pquery_IMG" VALUE="/icons/icon_info.gif">
> <PARAM NAME="TB_BUT_pquery_IMG_PR" VALUE="./images/tool_info_2.gif">
> <PARAM NAME="TB_BUT_pquery_HINT" VALUE="Point Query: Click a point on the
> map|for information about that point">
> <PARAM NAME="TB_BUT_pquery_INPUT" VALUE="auto_rect">
> <PARAM NAME="TB_BUT_pquery_NAME" VALUE="zoomdir">
> <PARAM NAME="TB_BUT_pquery_VALUE" VALUE="4">
> </APPLET>
> The error messages are the following (from the Netscape java console):
> Netscape Communications Corporation -- Java 1.1.5
> Type '?' for options.
> Symantec Java! ByteCode Compiler Version 210.065
> Copyright (C) 1996-97 Symantec Corporation
> java.io.IOException: <null>
>   at netscape.net.URLConnection.connect(Compiled Code)
>   at netscape.net.URLConnection.getInputStream(Compiled Code)
> * at netscape.applet.AppletClassLoader.grabArchiveFile(Compiled Code)
>   at netscape.applet.AppletClassLoader.openArchive(Compiled Code)
>   at netscape.applet.AppletClassLoader.<init>(Compiled Code)
>   at netscape.applet.AppletClassLoader.getClassLoader(Compiled Code)
>   at netscape.applet.DerivedAppletFrame$LoadAppletEvent.dispatch(Compiled
> Code)
>   at java.awt.EventDispatchThread$EventPump.dispatchEvents(Compiled Code)
>   at java.awt.EventDispatchThread.run(Compiled Code)
>   at
> netscape.applet.DerivedAppletFrame$AppletEventDispatchThread.run(Compiled
> Code)
> # Unable to load archive /cgi-bin/rosa.jar: java.io.IOException: <null>
> # Applet exception: class Rosa2000 could not be loaded
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
