An old question!!
aborruso at spaziogis.it
Mon Oct 16 10:19:14 EDT 2000
Dear all,
I would like to view in a map, by itemquery, for example only that city (a
point theme) that I have selected by an html form. I'm able to do it by
querymap and mapext=shape but the point appears to me il the left corner of
the map. I know that it's an old problem and I have just received some
ansers (for example using buffer), but I have had no result. I'm attaching
my shapefile my template file for the query result and my map file. I'm
actually point to this template by this example syntax:
http://../mapserv?map=query.map&mode=itemquery&item=NUM&value=001. I would
like to see only my selected city in the middle of the generated map.
Thank you,
Andrea
(See attached file: usgs5.map)(See attached file: samplesutm.shx)(See
attached file: samplesutm.sbn)(See attached file: samplesutm.sbx)(See
attached file: samplesutm.shp)(See attached file: samplesutm.dbf)(See
attached file: usgs5.htm)
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/usgs5.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/samplesutm.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/samplesutm-0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/samplesutm-0002.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/samplesutm-0003.obj
Type: application/x-lotus-approach
Desc: Lotus Approach
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/samplesutm.bin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20001016/7767460a/usgs5.htm
