Java applet won't load
Brian Fischer
Brian.Fischer at co.sherburne.mn.us
Wed Oct 18 13:26:29 EDT 2000
Sorry for the question, I should of tried this first. It turns out the .class file I was using got corrupted in a transfer. I just downloaded the file again and now the applet works fine.
Brian
>>> "Brian Fischer" <Brian.Fischer at co.sherburne.mn.us> 10/18/00 10:22AM >>>
Mapserver Users,
I am trying to use a java applet in a mapserver application. Here is the HTML code:
<applet codebase="/java/" code="mapimage.class" width="400" height="400" name="mapimage" MAYSCRIPT>
<param name="image" value="http://nt3000/gis/temp_mapserv/[img]">
<param name="jitter" value="15">
<param name="color" value="255 0 0">
</applet>
The problem is the web browser says "load: class mapimage not found". Where is the web browser looking for the mapimage.class file?
I have the mapimage.class and mapimage.java in a directory on my webserver called java. (wwwroot/java/). I am using Microsoft IIS 4.0. I am not for sure if this is the write place to put the java code. Can anyone help?
Thanks,
Brian
