Setting up
Stephen Lime steve.lime at dnr.state.mn.us
Fri Oct 27 13:07:20 EDT 2000
Did you try a "shift-refresh"? That will force netscape to refresh it. Changes in the map
file are not known to the webserver so that's often needed. Using a "post" for forms will
also always result in a refresh. That said, "get" is more useful for debugging since you
can see what's being sent. Once communication is working and you're just tuning display
of the map with the mapfile I use "post" forms.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Lyndon Zimmermann <lyndon.zimmermann at adelaide.edu.au> 10/27/00 02:57AM >>>
Chris: I'll work through your suggestions, thanks.
Anyone: I struck a strange feature.  I was trying to understand the
extent object in the .map file so I reduced the minimum values on
Example 2 (a static shapefile), and the map zoomed out. Fine. I changed
them back, clicked reload on Netscape, and it didn't zoom back in.  If
I'm not achieving an effective refresh then debugging is going to be
tricky.  Any comments?
Lyndon Z
imap at chesapeake.net wrote:
> Lyndon,
> Boy I fought with RedHat 7 for a day or 2 trying to get things
> working with 3 different version of GD on that machine...  It is
> difficult to make it find the correct one.  I can tell you are
> going thru the same malfunction with your install.
