the .map file language
Stephen Lime
steve.lime at dnr.state.mn.us
Sun Oct 29 10:42:32 EST 2000
It's the same thing. Map files are NOT line but rather token based so:
LAYER NAME "mylayer" MINSCALE "240000"... END
Is perfectly valid. It's a matter of personal preference. Since I liked the line-based display and wrote the original demos that's probably why that has held on. A move to XML for input is planned but it's "heavy" too. The best reason I see for the XML move is the validation that comes along a mapfile DTD.
Steve
>>> <nwerneck at yahoo.com.br> 10/29/00 04:36 AM >>>
Hi...
Isn't that .map file language just too "vertical"?? A line per
attribute of each object makes it a "low-density" language. You
need a lot of lines to pass little information.
Wouldn't it be nice to have some HTML-like language... Dig it
(do you still say this? :) ):
<LAYER name="cities" data="cities" type="point">
<CLASS expression="/myxtplikz/" maxscale="5"
minscale="20" size=5 symbol=3>
<LABEL type="truetype" font="new-gotic" size="5">
</CLASS>
<CLASS expression="/lex luther/" maxscale="5"
minscale="20" size=3 symbol=2>
<LABEL type="truetype" font="new-gotic" size="4">
</CLASS>
</LAYER>
if i'm not mistaken, you can't have two label items per class, so,
maybe we can make that in a different way... maybe some lisp--
like language
(LAYER name="cities" data="cities" type="point">
(CLASS expression="/myxtplikz/" maxscale="5"
(LABEL type="truetype" font="new-gotic" size="5"))
(CLASS expression="/lex luther/" maxscale="5"
(LABEL type="truetype" font="new-gotic" size="4")))
Even better isn't it??? Of course, you still can take advantage
from the old-fashined way. Mybe puttting the attributes in different
lines make it easier to locate the ones we're configuring some time.
(CLASS
maxscale="5" minscale="20"
symbol=3 size=5
well, I'm done for the moment... :)
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
