maxscale & classes
Robin.Ellis at dnr.qld.gov.au Robin.Ellis at dnr.qld.gov.au
Sun Oct 29 19:36:06 EST 2000
Does anybody know why I can't utilise a maxscale with a tiled layer that has
multiple class names? I've included the layer definition from my mapfile
below. The functions properly if I have it in the exact format below (you'll
notice that most of the class names have been nullified by the #). However,
if I try to include any more of the class names by removing the # the whole
system will not load properly.I seem to be limited to only including 2 class
names per layer that has a maxscale attribute included. Alternatively, I can
remove the maxscale attribute to allow all class names to be included, but
this is not an acceptable solution for this system.
We're using a Java based application on a Unix platform.
The layer definition is:
LAYER
  NAME res
  TYPE POLYGON
  STATUS on
  MAXSCALE 250000
  TOLERANCE 0
  TILEINDEX /data4/WWW/projects/vegmgt/qdemo/coverages/se_shires
  TILEITEM retile
    CLASSITEM vm_stat_id
      CLASS
        EXPRESSION '1'
	NAME "Dominant Endangered Remnant"
        COLOR 202 0 220
        OUTLINECOLOR 202 0 220
     END  # CLASS
      CLASS
        EXPRESSION '2'
	NAME "Sub-dominant Endangered Remnant"
        COLOR 247 165 255
        OUTLINECOLOR 247 165 255
     END  # CLASS
      CLASS
        EXPRESSION '3'
#	NAME "Dominant Of Concern Remnant"
        COLOR 255 191 0
        OUTLINECOLOR 255 191 0
     END  # CLASS
      CLASS
        EXPRESSION '4'
#	NAME "Sub-dominant Of Concern Remnant"
        COLOR 220 206 0
        OUTLINECOLOR 220 206 0
     END  # CLASS
      CLASS
        EXPRESSION '5'
#	NAME "Not Of Concern Remnant"
        COLOR 146 174 47
        OUTLINECOLOR 146 174 47
     END  # CLASS
      CLASS
        EXPRESSION '6'
#	NAME "Plantation forest"
        COLOR 247 247 222
        OUTLINECOLOR 247 247 222
     END  # CLASS
      CLASS
        EXPRESSION '7' # regrowth
        COLOR 255 255 255
        OUTLINECOLOR 255 255 255
     END  # CLASS
      CLASS
        EXPRESSION '8' # clear
        COLOR 255 255 255
     END  # CLASS
      CLASS
        EXPRESSION '9'
#	NAME "Dam or water"
        COLOR 135 164 254
        OUTLINECOLOR 135 164 254
     END  # CLASS
      CLASS
        EXPRESSION '10' # mine
        COLOR 255 255 255
     END  # CLASS
      CLASS
        EXPRESSION '11' # no data
#	NAME "No data"
        COLOR 200 100 100
     END  # CLASS
END # layer
Thanks
Rob
Robin Ellis
Land Resources Officer
Department of Natural Resources
Burnett District
ph: 07 4131 5771
fax: 07 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
