Setting up
Lyndon Zimmermann
lyndon.zimmermann at adelaide.edu.au
Sun Oct 29 21:39:20 EST 2000
Steve,
yes, shift-refresh did the trick. Thanks.
Lyndon Z
Stephen Lime wrote:
> Did you try a "shift-refresh"? That will force netscape to refresh it. Changes in the map
> file are not known to the webserver so that's often needed. Using a "post" for forms will
> also always result in a refresh. That said, "get" is more useful for debugging since you
> can see what's being sent. Once communication is working and you're just tuning display
> of the map with the mapfile I use "post" forms.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Lyndon Zimmermann <lyndon.zimmermann at adelaide.edu.au> 10/27/00 02:57AM >>>
> Chris: I'll work through your suggestions, thanks.
> Anyone: I struck a strange feature. I was trying to understand the
> extent object in the .map file so I reduced the minimum values on
> Example 2 (a static shapefile), and the map zoomed out. Fine. I changed
> them back, clicked reload on Netscape, and it didn't zoom back in. If
> I'm not achieving an effective refresh then debugging is going to be
> tricky. Any comments?
> Lyndon Z
