queryUsingPoint returning incorrect record number??
Sean O'Hagan
seano at metavera.com
Tue Sep 12 15:40:55 EDT 2000
Hello yet again :-)
I thought I'd verify that the set of points returned to me with
queryUsingPoint matched what I obtained visually using ArcExplorer. The
point sets returned by both MapScript and ArcExplorer were:
MScr ArcE
2797 2798
2799 2800
2801 2802
2802 2803
2803 2804
2804 2805
2806 2807
2807 2808
2809 2810
2811 2824
I thought perhaps there was a pattern, ie. mapscript was returning the
"correct record number minus one". In fact this is what happens when I
restrict the tolerance to only produce one point; instead of the correct
2804, I'm getting 2803. However, the last value of the table on the ArcE
side blows that theory out of the water.
Here's some code snippets:
Part of Map File:
<snip>
LAYER
NAME mylayer
TYPE point
TOLERANCEUNITS meters
TOLERANCE 100 #this generates one point, set to 1000 generates the ten
points shown above
STATUS default
DATA file_name
CLASS
SYMBOL 8
SIZE 8
COLOR 255 100 0
END
QUERY
TEMPLATE dummy
END
END
<snip>
My call to qUP:
<snip>
$qryResult = $mapfile->queryUsingPoint($point, 1, -1);
for (my $i=0; $i < $qryResult->{numresults}; $i++) {
my $shpResult = $qryResult->next();
$shapesref->[$i] = $shpResult->{shape};
<snip>
Metavera Solutions, Inc.
192 Spadina Ave., Suite 405
Toronto, ON
M5T 2C2
Tel: (416) 504-8351
Fax: (416) 364-2636
Email: seano at metavera.com
Fallback email: smohagan at yahoo.com
