Strange behavior ....
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Wed Sep 13 14:48:54 EDT 2000
Dan,
Yeah, that sounds about right ...
Although you're probably using our data :) Could the data itself be the
problem ?
J.F.
> From: Daniel Morissette[SMTP:danmo at videotron.ca]
> Sent: Wednesday, September 13, 2000 2:49 PM
> To: Doyon, Jean-Francois
> Cc: 'mapserver-users at lists.gis.umn.edu'
> Subject: Re: Strange behavior ....
> JF,
> We have an application that does something similar to yours: we display
> a layer of points in LAT/LON on top of a base map in LCC and we noticed
> the same thing as you. We haven't investigated the problem yet,
> though...
> Steve, are you aware of any PROJ.4 limitations that could explain that
> behavior? It seems to be that LAT/LON points located north of a
> specific latitude are lost. And the latitude at which points starts to
> disappear changes depending on the scale of the map: as you zoom in, the
> line where points start to disappear moves north.
> Any idea?
> Daniel
> "Doyon, Jean-Francois" wrote:
> > Hello !
> > Well, things are oging pretty well, but now I've run accross a strange
> > behavior
> > I was hoping someone could explain ...
> > When I map my search results (using php-mapscript as allways), I create
> > atemporary shapefile.
> > This shapefile use geographical coordinates, whereas the rest of the
> data
> > used to generate the
> > map uses a different projection (lcc to be exact).
> > Now for some reason, results don't seem to show up in the far north
> > (Nunavut) !
> > Actually, they do show up, but only once I zoom in ! Now, I am *NOT*
> doing
> > anything to that layer
> > that might do this, the layer is "ON" by default, and that's it. All the
> > Other symbols show up.
> > Actually results in Iqualuit show, but not other smaller Nunavut
> communities
> > ... Until I zoom in.
> > I'm wondering why this might be, and how to fix it ... I'm guessing the
> > projection conversion might
> > have something to do with it ? But that's out of my area of expertise
> > Any ideas ?
> > Thanks,
> > Jean-Francois Doyon
> > Internet Service Development and Systems Support
> > GeoAccess Division
> > Natural Resources Canada
> > (613) 992-4902
> Daniel Morissette danmo at videotron.ca
> http://pages.infinit.net/danmo/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
