problem compiling PHP mapscript module
massimo ambrosini massimo at utilia.it
Sun Apr 1 12:50:40 EDT 2001
I'm trying to compile mapserver with php mapscript module but I get an error.
My os is linux and I have apache_1.3.12 and php-3.0.15.
PHP3 is statically linked into Apache.
When I run: ./configure --with-php3=../php-3.0.15
                 make
I get:     ap_config_auto.h: file not found
            ap_config.h: file not found
            .... and so on.
I've read the faq about this problem but it regards the use of php as DSO.
When I compile php3 source in apache building procedure  I use "--with-apache=../apache_1.3.12" so
the make process can find the header files like "ap_config_auto.h" etc.
When I compile mapserver source what can I do to avoid the file not found error on these header files ?
thanks
max
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010401/eccb0357/attachment.html
