[mapserver-users] error in php_mapscript with prepareImage
Daniel Morissette
morissette at dmsolutions.ca
Thu Apr 19 08:39:32 EDT 2001
Gert-Jan van der Weijden wrote:
> When I try to run my php_mapscript application
> I get the following error:
> Fatal error: Call to undefined function: prepareimage() in
> /project/webmap/www/pag/drawmap.php on line 291
Hummm... the function prepareImage() was implemented but was not
registered as a mapObj method. It was also the case for
prepareQuery()... I'll fix this for v.3.5.
If you want to patch your own copy, add the following lines in the
php_map_class_functions[] array definition, around line 400 in
php_mapscript.c:
{"prepareimage", php3_ms_map_prepareImage, NULL},
{"preparequery", php3_ms_map_prepareQuery, NULL},
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
