[mapserver-users] Shapefile Polygon problem (fwd)
teb teb at mallit.fr.umn.edu
Wed Aug 1 10:50:14 EDT 2001
------------- Begin Forwarded Message -------------
X-Originating-IP: [213.122.118.51]
To: mapserver-info at lists.gis.umn.edu
Subject: Shapefile Polygon problem
Date: Wed, 01 Aug 2001 12:18:05 +0000
Mime-Version: 1.0
X-OriginalArrivalTime: 01 Aug 2001 12:18:05.0348 (UTC)
FILETIME=[04509640:01C11A84]
Hello all,
I am a new Mapserver user and I am trying to display my own
shapefiles. I have tried a dummy polygon (four sides), which
worked fine and displayed in the browser.
However, when I try to load more complex shapefiles, I get the
following message:
msDrawShapefileLayer(): General error message. POLYGON layers
must be POLYGON shapefiles.
This occurs on every one of my own shape files which were created
in MapInfo and then translated into ESRI shape. I have checked
the shapefiles in ArcView and all
objects are correct according to the syntax I have used in the
Map File. For example if I have a Polyline layer, all objects in
my shapefile are polylines; if I have a POLYGON
layer, all objects in my shapefile are polygons. This message
occurs every time I try to load one of my shapefiles - even when
I am trying to load a POLYLINE layer!
Please could someone shed some light on this, as I am completely
stumped! Thanks for your time,
Rob
------------- End Forwarded Message -------------
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010801/2392c387/attachment.html
