[mapserver-users] msDrawRaster TileIndex TileItem Location
Pericles S. Nacionales
pnaciona at gis.umn.edu
Wed Aug 1 14:41:39 EDT 2001
Richard, et al.
To get back on the original question, the reason it doesn't work is because
the network drive isn't mapped when MapServer makes the read request. You
probably need to find a way to map drives while running as a service. The
web server itself can't help you here because it's MapServer that actually
reads the file.
I suppose you can write a script that maps a network path to your local
machine, and that can run as an NT service. Chances are you'll need a user
that can login as a service to do this. Could be more of a hassle with
security issues. You can try though, and I would like to hear what happens.
Good luck!
Perry N.
-----Original Message-----
From: owner-mapserver-users at lists [mailto:owner-mapserver-users at lists]On
Behalf Of Richard Greenwood
Sent: Monday, July 30, 2001 5:14 PM
To: mapserver-users at lists
Subject: [mapserver-users] msDrawRaster TileIndex TileItem Location
Hello All,
I am on an NT machine and I can't seem get my TileIndex to work when the
TileItem Location references a mapped network drive, or a UNC path. I get
an error:
" msDrawRaster(): Unable to access file. "
But it works fine with a local drive letter. Anybody have any knowledge of
this problem?
Thanks,
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich at GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
