[mapserver-users] How to color a polygon depending on one of its DBF attribute ?
Puneet Kishor
pkishor at GeoAnalytics.com
Tue Aug 7 09:36:42 EDT 2001
On Tuesday, August 7, 2001, at 01:16 AM, Speh Sylvain wrote:
> Hi list,
> Whichever is the map I'm looking at, they are all made on the same
> pattern :
> one class --> one color.
> I wonder how to get a layer whose polygons are filled with the color of
> an
> attribute or from a computed expression.
> Imagine there is a population layer ( 100 citizens for the less populous
> polygon , 10,000 for the more ).
> How can I color them like
> COLOR 43 196 x
> with x = 0 for 100 and x = 255 for 10,000, or else ( like/dark
> polygon ) ?
Well, you will still have one class --> one color. However, no one is
stopping you from breaking the layer into multiple classes. So, you have
a pop layer, and you have classes like so (check the correct syntax)...
classitem pop
class name 0-100
expression /0-100/ # check the syntax for reg exps, or use sql kinda
syntax
color firstcolor
class name 100-199
expression /100-199/
color secondcolor
class name 200-299
expression /200-299/
color thirdcolor
you get the gist.
as a bonus, if you are drawing the legend, you will also get a nicely
formatted, labeled legend.
have fun,
pk/
