[mapserver-users] Compilation/ESRI SHapeLIB
Richard Ford
mapserver at cubok.com
Wed Aug 8 02:08:33 EDT 2001
G'Dat Frank.
Was that version 3.3? Or a later one?
Cheers,
Richard.
----- Original Message -----
To: "Richard Ford" <mapserver at cubok.com>; "UMN MapServer"
<mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, August 08, 2001 3:14 AM
Subject: Re: [mapserver-users] Compilation/ESRI SHapeLIB
> Richard Ford wrote:
> > What do you mean by bastardised??
> > Is it limited or does it just suffice for basic reading and writing?
> Richard,
> Steve has optimized the shapelib code, partly by having it directly
> transform the incoming data into the internal format for MapServer instead
> of going through the intermediate format used by shapelib. It should read
> pretty much anything that the regular shapelib reads, but won't include
some
> of the latest shapelib tweaks.
> > As Stephen pointed out there is shape file support built in. Will I
still
> > need PROJ. What else is PROJ used for and should I really consider it a
> > mandatory library?
> If you have all your data into one coordinate system ... the coordinate
system
> you want to serve data in, then you don't need PROJ.4 libraries for
MapServer.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
