[mapserver-users] OGR Support for TIGER 2000 Data?
Rob Martinson
cathode at nichebox.com
Thu Aug 9 13:30:51 EDT 2001
Zip information via Zip Code Tabulation Areas from TIGER 2000 are now
available at: http://www.census.gov/geo/ZCTA/zcta.html. Or as boundary
files for each state from:
http://www.census.gov/geo/www/cob/z52000.html.
They have also made available online a database of ZIP codes compiled
from '99 information. This is the most recent freely available ZIP
information for the US that I know of. It contains zip codes, centroid,
placename, zip type, and FIPS for the country. I have parsed a copy of
this table and dumped them to a mySQL database on the server which I use
quite often along side Mapserver. This table from November '99 is
available at: http://www.census.gov/geo/www/tiger/zip1999.html
Hope this helps...
Rob Martinson
Nichebox - http://www.nichebox.com
> -----Original Message-----
> From: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of
> Kieran J. Ames
> Sent: Thursday, August 09, 2001 6:05 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [mapserver-users] OGR Support for TIGER 2000 Data?
> List
> It seems mapserver.gis.umn.edu is down. :(
> Questions...
> I'm trying to understand these TIGER files and can't quite
> grasp the record types. I'm wondering if ZIP CODES are
> available within these data, since my Zip code polygon files
> are a few years old. Thanks, Kieran
> Ed McNierney wrote:
> > Dawn breaks on Marblehead (as they say around here...)
> > Rob -
> > Thanks! I have no problems at all and my OGRINFO tests work, and
> > MapServer works.
> > Jeff threw me off the trail by naming the directory in
> which he stored
> > the TGR25001.* files "TGR25001". As a result, I thought he
> was simply
> > specifying the root name of the files - and that OGR would
> simply look
> > for TGR25001.* in the same directory as specified. Instead, he was
> > specifying the name of the DIRECTORY holding all the
> TGR25001.* files.
> > I'm happy - everything works. Thanks everyone for the help! Jeff,
> > you might want to update your excellent example pages to make this
> > distinction clearer.
> > - Ed
> > Ed McNierney
> > Chief Mapmaker
> > TopoZone.com
> > ed at topozone.com
> > (978) 251-4242
> > From: Rob Martinson [mailto:cathode at nichebox.com]
> > Sent: Tuesday, August 07, 2001 2:56 PM
> > To: 'Jeff McKenna'; Ed McNierney
> > Cc: 'Users'
> > Subject: RE: [mapserver-users] OGR Support for TIGER 2000 Data?
> > Okay, this was a bit confusing to me but I now see what Jeff is
> > saying. OGR must look at the entire directory of raw data
> to open any
> > of the layers instead of a single .RT* file. I thought Jeff
> just meant
> > that the full path to the file must be specified, but
> instead just the
> > directory where the layers reside must be specified.
> > For example, my TIGER data is in:
> > /usr/local/mapdata/TIGER_2000/WA/53063/
> > In this directory I have files TGR53063.RT1 through TGR53063.RTZ.
> > Instead of calling ogrinfo as:
> > ogrinfo /usr/local/mapdata/TIGER_2000/WA/53063/TGR53063.RT1
> > Try calling as:
> > So OGR can look at the entire data structure. Works for me
> on this end
> > now. Thanks Jeff!
> > Rob Martinson
> > Development - http://dev.nichebox.com
> Behalf Of Jeff
> > > McKenna
> > > Sent: Tuesday, August 07, 2001 4:01 PM
> > > To: Ed McNierney
> > > Cc: Users
> > > > Thank for figuring that out! However, I still can't get it
> > > to work.
> > > > I'm running the OGR tools I built (under Windows 2000)
> in the GDAL
> > > > 1.1.5 distribution. OGRINFO still refuses to recognize the
> > > data set.
> > > > Are you using a different OGR?
> > > Hi Ed,
> > > I just checked out the latest CVS version of GDAL
> (v1.1.5) and built
> > > it (under Windows NT), and OGRINFO works fine for me. Hmm. I
> > > placed OGRINFO into the directory where the TIGER data
> resides (i.e.
> > > placed TGR25001.RT1, TGR25001.RT2... in the same directory as
> > > OGRINFO). The syntax I used for OGRINFO is: $ ogrinfo
> > > full/path/to/data
> > > This worked fine for me. Maybe someone else has some ideas?
> > > Jeff McKenna
> > > GIS Specialist
> > > DM Solutions Group Inc.
> > > Ottawa, Ontario
> > > http://www.dmsolutions.ca/
