[mapserver-users] the infamous 'invalid _map_handle_' strikes again
Daniel Morissette morissette at dmsolutions.ca
Thu Aug 9 14:32:07 EDT 2001
"Vinko Vrsalovic B." wrote:
> Well, I finally got the time to upgrade from PHP4.0.3 to PHP 4.0.6.
> I'm using the latest CVS build of MS3.5 (08-01) and when executing this code:
> I get a:
> Fatal error: Object has an invalid '_map_handle_' property in /var/www/html/ms_demo/php/layer.php on line 11
> If I change the $l_stgo->draw($imag); line to $imag=$map->draw();
> it works perfectly.
Hummm this is bad!  I don't have time to look into this now but I have
filed the bug in bugzilla to make sure it doesn't fall in a crack...
  http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=30
 DM Solutions Group              http://www.dmsolutions.ca/
  Don't put for tomorrow what you can do today, because if
      you enjoy it today you can do it again tomorrow.
