[mapserver-users] shape->intesects
Daniel Morissette
morissette at dmsolutions.ca
Fri Aug 10 10:26:46 EDT 2001
Jean-François MONY wrote:
> I've some questions on the intersects fonction of a shape object.
> I've tried it on multi-part polygon and the result was not really fine.
> After some search, I find that the total inclusion of a polygon in another was
> not take in count by this function.
> After a look on the mapscript.i, I thought that the problem came from :
<snipped>
> But I've tried to recompil mapserver with the following modification, and
> nothing change.
> return msIntersectPolygons(self, shape); <<=======
> Is there somebody with a comment or an idea ?
PHP MapScript uses a modified copy of mapscript.i that is
C-compilable... it's in mapscript/php3/mapscript_i.c ... if you make
your change there then you should see the change.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
