[mapserver-users] Shapefiles
Richard Ford
mapserver at cubok.com
Wed Aug 15 21:12:07 EDT 2001
Thanks a lot.
That saves me two days as I waited for the install CD's of ArcView.
BTW - what would or can one do to show RASTER files. Again I know nothing
of GIS to well. I know that Raster is a format and that ArcIMS does not
display raster images. Does Mapserver display or can it display RASTER
images.
And if so - is a ratser image a very common type of file used in most GIS
applications? ArcView applications (models)?
Cheers,
Richard.
> Shape files only hold vector data: points, lines, polygons. So that
> should clear up one problem there :) Your test layer was declared as a
> raster (an image).
> Go to the ESRI web site (www.esri.com) and download their free tool,
> ArcExplorer. This program lets you view and query shape files
> interactively. You can use it to figure out what you're dealing with
> before trying to shoehorn them into mapserver.
> Best of luck,
> Paul
> Richard Ford wrote:
> > G'Day All,
> > Ok, I have been experimenting with Mapserver and I have a moderate grasp
on
> > the various files and configuration system. Not good enough to make a
> > polished site - but good enough to test appropriateness of technology.
> > Now I have a whole heap of shapefiles make in ESRI ArcView.
> > How do I load them! :)
> > I have made my own .map files and templates - heavily based on the
MS_DEMO
> > download.
> > I have the shapefiles ready and shapepath set.
> > Do I need to have the exact type set like raster, line, polygon, etc...
As
> > I have tried various shapefiles and colour options and all I get is a
blank
> > square were I was expecting some sort of image?
> > # Start of map file
> > NAME LANCE
> > STATUS ON
> > SIZE 1200 1200
> > #SHADESET symbols/shade.sym
> > #MARKERSET symbols/marker.sym
> > #LINESET symbols/line.sym
> > EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
> > #UNITS METERS
> > SHAPEPATH "/usr/local/apache/htdcos/lance/risk_data"
> > #IMAGECOLOR 255 255 255
> > # Start of web interface definition
> > WEB
> > HEADER demo_header.html
> > TEMPLATE demo.html
> > FOOTER demo_footer.html
> > MINSCALE 1000
> > MAXSCALE 1550000
> > IMAGEPATH "/usr/local/apache/htdocs/tmp/"
> > IMAGEURL "/tmp/"
> > # LOG "demo.log"
> > END
> > QUERYMAP
> > SIZE 200 200
> > STATUS ON
> > STYLE HILITE
> > COLOR 255 0 0
> > END
> > # Start of reference map
> > #REFERENCE
> > # IMAGE graphics/reference.tif
> > # EXTENT 393234.393701263 5205405.16440722 495769.579718949
> > 5307959.02579127
> > # SIZE 120 120
> > # STATUS ON
> > # COLOR -1 -1 -1
> > # OUTLINECOLOR 255 0 0
> > #END
> > # Start of legend
> > LEGEND
> > KEYSIZE 18 12
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > STATUS ON
> > END
> > # Start of scalebar
> > SCALEBAR
> > LABEL
> > COLOR 255 255 255
> > SIZE tiny
> > END
> > STYLE 1
> > SIZE 50 2
> > COLOR 255 255 255
> > UNITS MILES
> > INTERVALS 1
> > TRANSPARENT TRUE
> > STATUS TRUE
> > END
> > # Start of layer definitions
> > LAYER
> > NAME "test"
> > TYPE RASTER
> > STATUS DEFAULT
> > DATA disslv1
> > CLASS
> > COLOR 250 140 250
> > END
> > END
> > END # Map File
> > disslv1 is a shapefile (well the 3 files, .shp, .shx, .dbf) and nothing
> > loads?
> > I even changed the data to a known shapefile in the ms_demo directory
and
> > copied the same layer definition and I still got a blank box (But always
> > with a working navigation system).
> > Demo_init.html is set to load 'test' as a default layer.... clicking on
the
> > "re-display/query button still shows an empty square?
> > I will not be meeting the creator of the shapefiles until Friday and I
guess
> > I will need more info about what is inside them to be able to define a
layer
> > to display them? I guess what I really wanted to do was to have a
working
> > system - though that just shows a basic map with 1 layer so he can see
it.
> > Proof of technology - to prove that mapserver is what we want to use and
not
> > ArcIMS - urghhh!.
> > Many Thanks as I find my feet..... GIS expert - I am not. :)
> > Richard Ford.
> > richard at cubok.com www.cubok.com
> > The views expressed here are solely my own and do not necessarily
represent
> > those of my employer.
