[mapserver-users] SVG
Rob Atkinson rob at socialchange.net.au
Thu Aug 16 19:07:11 EDT 2001
Logically better to support GML, then you can choose a GML to SVG stylesheet
at runtime if you wish.
(keep data model and presentation separate!)
Would be interested in feedback re performance - its on a long to-do list
for us.
Big issue with vector formats is always the unpredicatability of response
size in a network environment. Leads to interesting issues re generalisation
on the fly. In the past I have used the maxfeatures to limit mapserver time
rendering - the same concept might work but what if the client zooms in?
Rob Atkinson
David Moffett wrote:
> Hello,
> I am thinking about adding SVG ( Scalar Vector Graphics ) to mapserver.
> My questions are:
> 1. Is someone already doing this?  There was some talk on the mailing in
> Oct 2000 but I  did not see a conclusion.
> 2. Is it a good idea?  I think it is since we would like to use it
> ourselves.
> 3. What approach would be best.  I have looked at the code and have some
> ideas but I am a far cry from an expert on mapserver.
> If I can come up with a good solution I will release back to the
> mapserver community.  Also I would be glad to pitch in and help anyone
> that has started with solution.  I will even try to comment the
> code.  :-)
> Thank you,
> David
> David B. Moffett
> Walnut Software, LLC.
Type: text/x-vcard
Desc: Card for Rob Atkinson
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010817/39dbc88a/rob.vcf
