[mapserver-users] Feature_ID
Stephen Lime steve.lime at dnr.state.mn.us
Mon Aug 20 12:12:58 EDT 2001
What version, datatype etc? Assuming there is an item called feature_id there's no reason it
shouldn't work. That said being able to use a psuedo id in classes is not a bad idea. That id
is already a part of the internal shape structures but it's not trivial to add that to the expression
handler. Would you add this as a feature request to Bugzilla?
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Jim Burnett" <jimburnett at ntelos.net> 08/17/01 12:55PM >>>
Why can't I use Feature_ID as a CLASSITEM?
I have a line layer, which has other attribute data, but no matter which of the fields I use, none work. Why cant I just use the standard FeatureID.   its just for display only.
-jim
