[mapserver-users] on the fly projection modifications
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Aug 27 15:57:04 EDT 2001
It can be done. You need to use lat/lon coordinates to move between different
projections. No biggie in your case. You can change the output projection using
the "map_projection" parameter and you set it's value to a comma delimited
string of proj options. For example:
"proj=lcc,lat_0=49n,lon_0=95w,lat_1=49n,lat_2=77n"
anything spit out at that point will be in that new coordinate system. One caveat might
be that you should set the new projection BEFORE passing the extent but I'm not
positive about that.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Kralidis, Tom" <Tom.Kralidis at CCRS.NRCan.gc.ca> 08/27/01 02:31PM >>>
Anyone have any experience / suggestions on how to change projection params
on the fly within a MapServer web app?
i.e. An existing .map file:
MAP
NAME CAN
EXTENT -180 -90 180 90
UNITS DD
TRANSPARENT ON
SIZE 500 300
WEB
TEMPLATE map.htm
IMAGEPATH /home/httpd/html/img_cache/
IMAGEURL "/img_cache/"
LOG process_log
END
LAYER
NAME world_at_night
TYPE RASTER
STATUS DEFAULT
DATA ../firemapping/world_stable_lights.tif
END
END
..then, in the web app, the user wishes to change projections to:
PROJECTION
"proj=lcc"
"lat_0=49n"
"lon_0=95w"
"lat_1=49n"
"lat_2=77n"
END
...how can one set this up via GET or POST. I'd like to have the page
refresh with coords in LCC, as per this example.
Thanks
..Tom
Tom Kralidis
Systems Scientist
Canada Centre for Remote Sensing
Tel: (613) 947-1828
http://www.ccrs.nrcan.gc.ca/
