[mapserver-users] Itemquery in Mapscript(PHP)
Laurent FOULONNEAU
adsllaurentf at canl.nc
Thu Aug 30 07:48:27 EDT 2001
Could certainly be improved.....
First you have a blank image, when you use the search form, your object is
'automagically' ;) zoomed and painted in red
The others object are not showed.
Laurent
//--------------------------------------begin draw_query.php
<HTML>
<?php
dl("php_mapscript.dll"); // PHP4
// variables globales
$map_obj= ms_newMapObj("yourmapfile.map");
$red = $map_obj->addColor(255, 0, 0);
// fonctions
function DrawQueryMap()
GLOBAL $map_obj,$mode,$item, $qlayer, $value,$red;
if($qlayer && $mode == "itemquery" && $value && $item)
$layer = $map_obj->getlayerbyname($qlayer);
for ($c=0; $c < $layer->numclasses; $c++)
$class=$layer->getclass($c);
if ($class->name == $item)
$class->setExpression($value);
$class->set("color", $red);
$img = $map_obj->draw();
$url = $img->saveWebImage($img, 0, 0, -1);
echo"<INPUT TYPE=image SRC=$url BORDER=0 WIDTH=$map_obj->width
HEIGHT=$map_obj->height NAME=mainmap>";
<HEAD>
<?php DrawQueryMap() ?>
</HEAD>
<FORM>
<input type="hidden" name="mode" value="itemquery">
<input type="hidden" name="item"
value="your_class_name_in_the_map_file">
<input type="hidden" name="qlayer"
value="your_layer_in_the_map_file">
<input type="TEXT" size="30" name="value" value="">
<input type="submit" value="Search">
</FORM>
</HTML>
//------------------------------------- end of draw_query.php
//-----------------------------yourmapfile.map : add a layer with a class
name and a classitem with the same name
LAYER
NAME your_layer_in_the_map_file
TYPE POLYGON
STATUS ON
DATA your_shape_file
CLASSITEM "your_class_name_in_the_map_file"
CLASS
NAME "your_class_name_in_the_map_file"
END
END # layer
//----------------end of layer definition
----- Original Message -----
From: "Arthur, John" <John.Arthur at voicestream.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, August 30, 2001 7:10 AM
Subject: [mapserver-users] Itemquery in Mapscript(PHP)
> Sorry if this is documented somewhere, but I couldn't find anything on how
> to perform an Itemquery in PHP mapscript(not cgi).
> I would like to type a search on a field (in a point or polygon layer) and
> return a map zoomed in on that search.
> John Arthur
> RF Technician
> Office: (757) 490-7221
> Cellular: (757) 692-1515
> Email: john.arthur at voicestream.com
> _~-^-~_
> VoiceStream
> W I R E L E S S
