[mapserver-users] Access file error on demo (fwd)
Pushkar Pradhan pushkar at ERC.MsState.Edu
Sun Dec 2 14:52:51 EST 2001
Rob,
If you have already created the directory tmp, then you need to give the
public read and execute access to it.
If you haven't created this directory you need to create it manually. I
think this is most likely your problem.
> >From talos at wdn.com  Sun Dec  2 03:12:05 2001
> Received: from lists.gis.umn.edu (lists.gis.umn.edu [128.101.73.109])
> 	by mallit.fr.umn.edu (8.9.3+Sun/8.9.3) with ESMTP id DAA14634
> 	for <teb at mallit.fr.umn.edu>; Sun, 2 Dec 2001 03:12:05 -0600 (CST)
> Received: from mail.wdn.net (mail.wdn.com [216.250.230.62])
> 	by lists.gis.umn.edu (8.9.3+Sun/8.9.1) with ESMTP id DAA27012
> 	for <mapserver-info at lists.gis.umn.edu>; Sun, 2 Dec 2001 03:15:20 -0600 (CST)
> Received: (from nobody at localhost)
> 	by mail.wdn.net (8.9.1/8.9.1) id MAA07196;
> 	Fri, 30 Nov 2001 12:22:14 -0500
> Date: Fri, 30 Nov 2001 12:22:14 -0500
> Message-Id: <200111301722.MAA07196 at mail.wdn.net>
> X-Authentication-Warning: mail.wdn.net: nobody set sender to talos at wdn.com using -f
> From: rsmith at talos.com
> To: mapserver-info at lists.gis.umn.edu
> Reply-To: rsmith at talos.com
> MIME-Version: 1.0
> Content-Type: text/plain
> Content-Transfer-Encoding: 8bit
> User-Agent: IMP/PHP3 Imap webMail Program 2.0.11
> Sender: talos at wdn.com
> Subject: Access file error on demo
> Content-Length: 309
> I just installed the version 3.3 mapserv for the first
> time.
> I followed the instlattion instructions closely, but
> can't seem to
> get around the error below.  Has anyone come across
> this?
> msSaveImage(): Unable to access file.
> (C:\Inetpub\wwwroot\tmp\DEMO10071408313056.gif)
> Thanks
> Rob
> rsmith at talos.com
PUSHKAR S. PRADHAN
Master's Candidate in ELECTRICAL ENGINEERING,
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
