[mapserver-users] New window for query results
stepan.kafka at centrum.cz stepan.kafka at centrum.cz
Mon Dec 3 09:06:13 EST 2001
There are several ways to get it via javascript code. Try for
instance:
newWin =window.open("", "resultsWin", "<my_win_properties>");
document.mapserv.target = "resultsWin";
document.mapserv.submit()
or
myURL = <here_assemble_your_query_url>;
newWin =window.open(myURL, "resultsWin", "<my_win_properties>");
Stepan Kafka
______________________________________________________________
> Od: "Maul, Andreas-Alexander" <Andreas.Maul at bgr.de>
> Komu: "'mapserver-users at lists.gis.umn.edu'"  <mapserver-
users at lists.gis.umn.edu>
> CC:
> Datum: Mon, 3 Dec 2001 11:07:17 +0100
> Předmět: [mapserver-users] New window for query results
> Hi,
> is there an easy way to open a new window for showing query
results whereas
> the map and navigation window remains visible? I tried to use
the javascript
> window.open method in the query template file (which itself
redirects the
> call via the "refresh" meta tag to a php script file for a
database query)
> and in the file with the php query. However every time the
results popped up
> in the same window. Or must I do the window handling in the map
template
> file?
> Thanks in advance,
> Andreas
Informace bez čekání jen na Vaše zavolání. Nová služba České pošty: 0800/10 44 10; info at info.cpost.cz
http://user.centrum.cz/redir.php?url=http://www.cpost.cz/Aktuality/Default.htm
