[mapserver-users] Mapplet under 3.5 (FWD)
teb
teb at mallit.fr.umn.edu
Fri Dec 14 14:15:13 EST 2001
------------- Begin Forwarded Message -------------
To: mapserver-info at lists.gis.umn.edu
Subject: Mapplet under 3.5
Date: Fri, 14 Dec 2001 11:51:01 +1100
MIME-Version: 1.0
I have just upgraded an application using the Mapplet applet from
3.3 to 3.5. Everything appears to be working except the map image
does not display. I have checked the output PNG file (as listed
in the source HTML code) and it is fine. For some reason my
application just won't dipslay it. Are there any issues with
running the Mapplet applet under 3.5 that I need to allow for?
Thanks in advance
Stuart Row
Bureau of Rural Sciences
PO Box E11
Kingston ACT
Ph: +61 6272 4640 Fax: +61 6272 4687
Email: stuart.row at brs.gov.au
------------- End Forwarded Message -------------
