[mapserver-users] Micro-HowTo Display SCALE
Stephen Woodbridge woodbri at swoodbridge.com
Fri Dec 14 17:37:15 EST 2001
Steve,
I've posted this back to the list, maybe one of the developers can help
with this. I thought the number of decimal places was a bit excessive
myself :)
The only way to trim this up in html would be to write some javascript
We seem to have a lot of Steves posting to this list!
  -The other Steve!
klehr1 at tampabay.rr.com wrote:
> Thanks for the tip.
> I just tried it out and I got Scale: 1:21600.000000
> Is there away to tone down the decimals (%.2f) ?
> Not sure if you can do this with Mapserver directly, but maybe you can
> format the output in a later release.
> Thanks
> Steve Lehr
> ----- Original Message -----
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: Twan Kogels <twan at twansoft.com>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, December 14, 2001 9:26 AM
> Subject: [mapserver-users] Micro-HowTo Display SCALE
> > Hi all,
> > Twan Kogels asked about the values on the MINSCALE and MAXSCALE and how
> > they relate to a given map.
> > Go to your demo.html file and search for "scalebar" then replace that
> > line with the following:
> >       <td align="right" valign="top"><font size=-3
> > face="arial,helvetica" color="#FFFFFF">1:[scale]</font>&nbsp;&nbsp;<img
> > src="[scalebar]"></td>
> > Now just to the left of your scale bar you will have 1:ssssss.ssss where
> > ssssss.ssss is the scale of the map at whatever zoom you are at. This is
> > in the same units as the valuse on MINSCALE/MAXSCALE
> > PLEASE, add this to the appropriate documentation as and example.
> > Hope this helps,
> >   -Steve
