[mapserver-users] generate shape file
Daniel Morissette
morissette at dmsolutions.ca
Sat Dec 15 13:26:09 EST 2001
Hussain,
Your code attempts to write lines/polylines (MS_SHP_ARC), but you set
only one point (x,y pair) per line... that may well be the source of
your problems... you need at least two points to define a line or a
polyline.
Daniel
Shaik Anwar Hussain wrote:
> Hi List,
> Does any one know whats the wrong in this code,
> this code generating the shape file but when i open the shape
> file in arcview i am not getting the lines.
> <?php
> dl("php_mapscript.dll");
> dl("php_dbase.dll");
> function createshape( $x, $y, $programId )
> GLOBAL $shpFile,$dbfFile;
> $oShp = ms_newShapeObj(MS_SHP_ARC);
> $oLine = ms_newLineObj();
> $oLine->addXY($x, $y);
> $oShp->add( $oLine );
> $shpFile->addShape($oShp);
> dbase_add_record($dbfFile, array($programId));
> $shpFname = 'C:\Program Files\Apache Group\Apache\htdocs\php\test5';
> $shpFile = ms_newShapeFileObj( $shpFname, MS_SHP_ARC);
> $dbfFile = dbase_create($shpFname.".dbf", array(array("PROG_ID","N",5,0)));
> createshape( 12, 34, 111);
> createshape( 22, 14, 222);
> createshape( 10, 20, 333);
> echo "Shapes Created.<BR>";
> $shpFile->free();
> echo "Shape File ($shpFname) closed.<BR>";
> dbase_close($dbfFile);
> echo "Dbase file closed. <br>";
> i am using php 4.0/mapscript 3.4 module.
> Please try to look this problem.
> Thanks for ur time,
> Hussain
